Is there any chance of a 1TB Xbox Series S mod?
Is there any knowledge on if the Xbox Series S could potentially support larger drives as the 512 GB is quite small, and the expansion card is ridiculously over priced at £220
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Seems possible, the method is the same used on Xbox Series X.
The expansion slot on those consoles are simply CFExpress, you can buy a CFExpress to m.2 converter and install another SSD on it.
The Xbox S/X has SSD hardware whitelisting implemented, so you have to buy the same model number Microsoft got for SSD>
このアンサーは役に立ちましたか?
Would you happen to know a good place to buy a 1 or 2 tb version of this ssd?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 619
