メインコンテンツにスキップ
Also sold under the GMC Sierra and VIA Vtrux names, available in the US, Canada, Mexico and other countries around the world.
81回答 すべてを表示
Why will my windows roll down but not up?
I have an 04 Silverado, my driver door window will go down but you have to angle and mess with switch to finally get it to but it won’t go up and my passenger window only goes down? I’ve been told it might be the switches or window motor
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
@braydenprice this “you have to angle and mess with switch “ is a pretty good indication that it is the switches that are giving you trouble. I would start with replacing those first.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Your window is controlled by a window motor, which turns the window regulator. This regulator utilizes cables to raise and lower the door windows.
Over time that cable loses lubricant and also will fray.
This causes the cable to no longer slide through the channels in which it is routed.
Most often requiring replacement of the window regulator, which can be done without the need to replace the window motor.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brayden Price さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 41
今までの合計 1,202
