Replaced Screen. iPhone 11 won't boot only shows flashing apple logo.
So i fitted a brand new replacement screen to an iphone 11. However, This time the phone is now showing a flashing apple logo really quick then stops for 10 seconds and shows it again. I can access the restore function however, phone is also unable to restore… I did a full restore before changing the screen and all was working fine. Apart from the obvious damaged screen. I’m kinda thinking the screen is defective but it shows the restore information fine so I know the screen is working… Is there anything i can do or should i just request a replacement screen. I am using a high quality display from iTruColor and it should be working normally.
この質問は役に立ちましたか?
4 件のコメント
does the phone hold battery also this could be caused by the screen not being on right also did you disconnect the battery before putting on the new screen
keith_themuscovyduck さんによる
@keith_themuscovyduck No I only disconnected the screen and it had about 40 percent in it when I powered off for the repair...
Digitalclock さんによる
@keith_themuscovyduck also what do you mean by the screen not being on right? do i have to properly put the seal in and secure down before trying to boot?
Digitalclock さんによる
My battery connector is connected and I'm still having this issue, any recommendations?
Alexander Duarte さんによる
