メインコンテンツにスキップ
Samsung Galaxy Note IIは、大型ディスプレイと一体型自己記憶スタイラス用に最適化されたソフトウェアを組み合わせたスマートフォンでとして知られています。
211回答 すべてを表示
Won't power on and no charge light
Was working when I put it in a drawer, pulled it back out after maybe a year and it just won’t power on or give an led indicator it is connected to power.
Tried the cord I had been using in the past to charge it and nothing, cord is fine.
This was a replacement phone I had used for less than a year, it was stored with the battery installed, no leaks, water damage or drops and has lived in a otterbox since day 1.
Wasn’t rooted or custom firmware either.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
John Redkurn follow the official Samsung troule shooting flow chart.
The inoffical thing to do is to change your battery. It has discharged below its charge threshold and will no longer hold a charge. After that, re-evalaute.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Issue is it won’t power on even without the battery installed.
I cannot recall if I’ve had it powered on in the past without a battery, so I will ask.
wouldn’t it power on while connected to the charger or other power source without the battery?
さんによる
John Redkurn in theory yes in practice it may prevent your phone from coming on if it shortens out or is reported as follows. Again it is part of tge troubleshooting as well.
さんによる
コメントを追加
回答を追加する
John Redkurn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 30
