Turn signals not working
My turn signals aren’t working on my 2001 Cherokee. I replaced 2 bulbs and checked all the rest. When I force the right signal it blinks once then nothing
@lbrannock11 check the blinker relay because that could be what is causing this. Not a terribly complicated job. This video makes a pretty good job of showing you how to replace it.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 314
2 件のコメント
Changing the relay lit up the signals so I can manually make them work but it stopped my hazards from working. This is as far as I can go as I can’t take off the steering wheel
Lisa Brannock さんによる
@lbrannock11 you made sure that you have the proper bulbs in your lights? Some of the multi filament lights can cause this if they are the wrong type.
oldturkey03 さんによる
