Nintendo 2DS XL won't turn on without being connected to charger.
2DS XL wont turn on without the charger. It could turn on before I replaced the screen. Now it wont turn on for some reason. Was hoping if there's some sort of fix.
Hi,
That typically means that the battery is completely shot. The system basically sees the device with no battery attached. That’s why it will die immediately if you unplug it. I would recommend replacing the battery.
Jason
このアンサーは役に立ちましたか?
Hi, I replaced the battery with a spare one from another 2ds and it didn't work. Both batteries worked on the other 2ds tho.
At that point, I would start thinking it’s a motherboard issue.
Omg this happened to me years ago but I'm in electrical engineering school now and can actually fix it so imma give it a go
このアンサーは役に立ちましたか?
Nice, but I fixed it long time ago. It was the fuse close to the battery. Changed it and it worked again.
過去 24時間: 1
過去 7 日: 3
過去 30 日: 7
今までの合計 201
Can you use a multimeter to check the voltage of the battery?
Andrew S さんによる
@andrewsawesome No, but the battery works. Thought it was the battery so I replaced it with a spare one from another 2ds since they were the same and it didn't work. Both batteries worked on the 2ds tho.
Asura Destroyer さんによる
check connections to the battery on the gameboy side of things. if u have a multimeter that would be the best way.
Logixal さんによる
