メインコンテンツにスキップ
Repair information for the SteelSeries Arctis Pro wireless headphones. Released in March of 2018. Model number: 61743.
49回答 すべてを表示
PC not detecting my receiver through the given SteelSeries usb cord.
I have been using the headset for a while now and one day it just stopped working. I randomly got an alert that says, “The last USB device you connected to this computer malfunctioned and Windows does not recognize it”. My headset will connect to the receiver but the receiver wont connect to my PC. I know the issue is not with my PC because I tried connecting through the receiver to my laptop and got the same problem. Any help is much appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
Hi @mason3543353553 ,
You may have a faulty USB cable.
Usually there are 4 wires in a USB2.0 cable, two for power and two for data.
If one of the two data wires is faulty, (fractured, loose connection in plug etc) then the receiver cannot communicate with the host computer.
I don’t know the device but it appears as though it has a USB 2.0 to USB-C cable, is this correct?
Below are images of the two plug connections. Use an Ohmmeter to check for continuity of the two data wires from pins 2 & 3 in the USB 2.0 plug to pins A7 & A6 in the USB-C plug.
Alternatively just try another compatible cable and check if it works OK.
(click on images to enlarge).
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Thanks for the suggestion! I purchased a replacement cable off of amazon and I will let you know if that works when it arrives.
さんによる
Unfortunately replacing the USB cable did not work. I still got the same error message.
さんによる
@mason3543353553
If trying a different compatible USB cable didn't work then there appears to be a problem with the receiver's USB section. It may be hardware or software. The receiver's BT section seems to be OK as you can pair it with the headphones.
You may have to open the receiver and check for any obvious damage to the board i.e. loose USB connector for example.
If nothing is obvious then board level fault finding will be difficult as there are no schematics available online or none that I can find anyway.
How old are the headphones? If <12 months (24 months in EU countries) go the warranty route first to get it fixed, before opening the receiver and voiding the warranty.
さんによる
Ok I will try that, thank you for all of your help.
さんによる
コメントを追加
回答を追加する
Mason さん、ありがとうございました!
統計データ:
過去 24時間: 14
過去 7 日: 46
過去 30 日: 242
今までの合計 3,214
