Need help identifying RJ45 ethernet replacement part.
I need a part number or a link to the proper RJ45 modular connector.
my device is a unifi protect g4 dome model number UVC-G4-DOME
Hi @gizmowizards ,
Don’t know the answer but have you tried scanning the QR code on the bottom of the connector as shown in the 2nd image above to see if that gives any further information?
Alternatively try searching here or here with the RJ45 parameters that you know e.g. 6 pin or 8 pin, through hole etc and then check the data sheet of the more likely ones to see if they are compatible with mounting on the circuit board.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 14
今までの合計 334
1件のコメント
I also need to replace this port, where were you able to find a replacement for this port/module
Thomas Decock さんによる
