Is the power supply actually dual voltage?
I’m moving to the UK and wondering whether my TCL 55P607 might be secretly dual voltage. I understand it is common practice to label TVs as 110-120V only even though the power supply can actually take 110-240V.
Before I open up the back and take a peek, I was hoping someone else would have an answer. I believe the part number is 08-PN2G10L-PW200AA but looking at the PCB photos online, I don’t see any indication one way or another. Any hints would be appreciated!
この質問は役に立ちましたか?
7 件のコメント
They sell adaptors so you can safely use devices from the USA in the UK. Might just play it safe n get one
brandon k さんによる
@brandon_k
Hi Brandon, It wont work. Those adapters are only for the plug shape. For voltage you would need a heavy, fairly large transformer and then there are the different power frequencies - 60Hz vs. 50Hz. True some items are rated 50 or 60 Hz but you would have to check.
mike さんによる
A transformer would work but as @brandon_k said it's heavy and large so I'd like to avoid getting one if I can.
szx さんによる
@szxzx
Why not just contact TCL:
https://www.tcl.com/us/en/products/home-...
mike さんによる
@mike because the TV has a label on the back that says 110V, so even if it's 110-240V in practice they won't say so. Even if it's only a matter of regulatory approval etc.
szx さんによる
2件以上のコメントを表示
