メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2.3GHz, 2.6GHz, or 2.7GHzクアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大3.7GHz) 6MB 共有L3 キャッシュ付き。
some keys doesn't work after battery replacement
Hello folks,
Just replaced the battery for my 15” MacBook Pro (mid-2012). So far, the new battery is working as expected. However, some of the keyboard keys (Space, Delete, Cap lock, left arrow, down arrow) are not working!
I tried the following:
  1. Reset SMC
  2. Reset PRAM
  3. Disconnect and reconnect the keyboard cable
  4. Checked system settings
None of these helped.
Any suggestion? Please help!
Thanks in advance
Here is how the keyboard cable looks like:
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
I would inspect the keyboard cable and the connection to the logic board.
Disconnect the battery and carefully slide out the ribbon cable from the socket use cotton swab (Q-Tip) with some reagent grade Isopropyl alcohol to wipe the contact surface, if it looks damaged you may need a new keyboard.
Refer to Step 24 & 25 here: MacBook Pro 15インチ Retina Display Mid 2012 のロジックボードの交換
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
Hi Dan,
Thanks for your feedback.
I tried to clean it as you suggested, with no luck. It does not look damaged to me.
What are the chances that this issue is a keyboard issue and not something else (since I didn’t remove the keyboard cable while replacing the battery and the face only a handful of keys are not working)? Changing the keyboard looks extremely painful task ?
Thanks again
さんによる
@mahrmm - Sorry, sounds like some of the solvent dripped into the keyboard ;-{
さんによる
thanks, Dan for your reply. the keyboard price is not much, but i dont think i have the guts to replace it myself.
さんによる
@mahrmm - One option is just replace the case assembly MacBook Pro 15" Retina (Mid 2012-Early 2013) Upper Case Assembly
さんによる
Thanks Dan, I dont think my mbp worth investing more on it in term of money and time. :)
さんによる
コメントを追加
回答を追加する
Maher さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 8
今までの合計 909
