Model A1288 / 8, 16, or 32 GB capacity
585の回答 すべて表示
Crackling sound from speaker/headphone port issues
My ipod has sustained no water or bad shock damage at the time of the problem occuring. When my ipod was plugged via firewire into a speaker system, someone unplugged it (not violently, I saw them) and it froze up. I reset, but the speakers make a low, quiet crackling noise, and headphone noise is oddly distorted. (not the phones, I tried multiple pairs.) I even did a full backup/ restore. Can I get a fix, with minimal hardware tampering/ solder if possible?
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメント:
Your ipod is listed as a Touch 2nd generation. So my answer is based on that device...:-)
による
コメントを追加
Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
当社のショップを閲覧する
3回答
最も参考になった回答
I am not sure what you had connected but the iPod touch 2nd generation does not support Firewire.
USB Support: Sync & Charge Firewire Support: None
Details: The iPod touch 2nd Gen does not offer a "disk mode" for file transfer, although third-party software is available. It also does not support Firewire.
Connectivity: USB, Audio* Ports: Dock, Headphone*
Details: *Unfortunately, just like the original iPod touch, the iPod touch 2nd Gen models do not support video out via the headphone jack, they only provide video out via the dock connector. Annoyingly, video out is only available while using an Apple cable, Apple dock, or another accessory with an "Apple Authentication" chip. http://www.everymac.com/systems/apple/ip... You may want to try to clean your audio jack. Hold it upside down and use a can of electronics cleaner (compressed air) and gently try to blow out any dust or debris. If your audio output is clear while you use a docking station, it is your audio jack that will need to be replaced. If the audio remains distorted while you are using a docking station, you are having trouble with the audio IC. Hope this will help. Good Luck
この回答は役に立ちましたか?
スコア 1
コメント:
Sorry, that's just what I called the port on the bottom. Any solution?
による
Which one is the audio IC? I have the same problem here.
による
コメントを追加
i have same problem and i have ipod 5
この回答は役に立ちましたか?
スコア 0
コメントを追加
sometimes if you use the ipod for a long period of time with the headphones plugged in and it is in your pocket the probe for the headhones can bend and crack the insert or the "headphone jack" this is a complex fix but if it is under warranty it should be able to be handled by apple. if not it will cost a pretty penny to replace
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
MrNS さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 20
今までの合計 3,535
