メインコンテンツにスキップ
タブレット型PC用修理ガイド。この小さなサイズと接着剤使用の頻度が高いため、タブレットの修理にはラップトップ修理よりも接着剤の作業が多くなります。
18890回答 すべてを表示
In General, Which is the Best Repairable Tablet available today?
It really doesn’t matter how old or new, but that it [a tablet] is purchasable and repairable also that parts are available. So looking back with what you have worked with, which Make and/or Models of tablets would you suggest to meet the mentioned qualifications ? Please also consider the current times for this advise going forward, too.
Isn’t there is a law that anything manufactured has to have parts available for ten (10) years ? I have heard that this is true for Car’s. I look forward to your experienced advise.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント:
In the EU, there is a law requiring appliances(like refrigerators and TVs) to be made repairable. This doesn't apply to phones, tablets, or computers.
さんによる
Here in the USA, Repairing has slowly reduced over time to become a higher revenue stream for the increasingly merged Tech suppliers. At least 40 plus years ago, here in USA, you could get your clothes repaired instead of buying new and automobiles were more self repairable as well as electronics. This has changed in my personal life here in America. Repairs by independent firms and customer's was Expected and a law was Not required to have been past for firms large and small in-order to follow. Sad !
さんによる
@airdail71 the USofA has become a service nation like so many others. Everybody got away from production because of Globalization. Good or Bad? Check it out https://www.dw.com/en/the-globalization-...
さんによる
コメントを追加
2件の回答
IPad 5,6,7 is great for that.
Digitizer and LCD are 2 seperate peices which saves alot of money if just the glass breaks.
Battery and charge ports are easialy available.
Only thing is the port is soldered to the board.
Besides that all other parts are also easy to source if needs be.
Must samsung Tab A series are usually very easy to open, and does not requirer you to remove the glass to access the internals. Must of those also have easily accessible parts minus a couple of exceptions.
I would not reccomends less known brands since parts will be hard to find.
I hope this helps.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
The only problem with iPads is that you need to take off the screen first. If you break the screen and digitizer, it costs an extra $200. I would recommend the Samsung Galaxy Tab A series.
さんによる
Tab A would probably be the easiest, with most parts available @andrewsawesome. I agree
さんによる
コメントを追加
@airdail71 that is a very subjective question and answers should be taken just like that. Repairability based on personal experiences will differ widely. I suggest that you check the guides for the tablets. IFixit has gone through many of those and added a repairability score to those. 10/10 being the best etc. This only goes for guides made by iFixit not general guides created by users. It’ll be a good starting point.
Update (08/23/2021)
@airdail71 I knew iFixit had a tablet repairability page somewhere. Check on here https://www.ifixit.com/tablet-repairabil... for the scores
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Harvey Rothenberg さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 19
今までの合計 878
