メインコンテンツにスキップ
Also known as the Mega Drive II, this is a smaller, lighter, 2nd-generation version of the popular Genesis console, released in 1993.
11回答 すべてを表示
Sega Genesis 2 will not boot, even though the power light comes on
My system worked fine recently, but today I powered it up and the BIOS screen wouldn’t show up. I disassembled the system, and all the inputs seemed to be soldered correctly. Is there something I might have overlooked, or might it be something related to the A/V cable? (The cable is an RF modulator cable, by the way.)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
Can you open up the unit? Does the motherboard smell like fish/fishy? Bad caps are a common problem on Genesis/Mega Drive units.
さんによる
@andrewsawesome I'm currently away from home, but when I get back on the weekend, I'll give it a check. I opened it up, but I didn't think to smell it.
さんによる
コメントを追加
1 件の回答
There might be something really wrong with your motherboard. Take apart the console and check for grime, dead or corroded caps, and corrosion. Maybe check the CPU/GPU?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
When I took it apart, I didn't see anything wrong with it.
さんによる
Try replacing the caps. The caps might be dead entirely.
さんによる
Also, there might be something really wrong with the board. Maybe, try getting a replacement board here: https://www.ebay.com/itm/154323420288?ch...
さんによる
コメントを追加
回答を追加する
Corey Ferreyra-Peterson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 348
