hammerhead gts 150 cc governor removal
I have a hammerhead go kart gts 150 cc and it tops out at 35.9 on a good day. It doesn’t have a regular speed governor. Instead it has an electrical governor. How do I remove it to go faster
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Not finding any info on how to remove it.. I did however pull this from the hammerhead manual. Maybe it will help. There's also some mods available, apparently, that will boost power. If the electronic governor is built into a control module you may be able to find software for that. But I can't find anything telling me where it is even located.
このアンサーは役に立ちましたか?
so can you just remove the bolt?
過去 24時間: 1
過去 7 日: 23
過去 30 日: 89
今までの合計 3,491
