iPhone XS bootlooping after hardware changes. Panic log pic attached.
Panic log pic is attached here. What does this mean? Where is the issue coming from
The picture looks like it’s on warp speed.
What hardware was replaced? Can you be more specific?
It says thermalmonitord failed to update its report.
このアンサーは役に立ちましたか?
The following was replaced:
Battery
Charging port
Wifi flex
Interconnect flex
Charging flex
Display.
Added betterr pic to post.
I took the first one in a pinch as the phone is bootlooping.
@Roro Missing sensor prs0, maybe a bad charging flex.
Looks like the prs0 sensor is missing stated in the log, means possibly a bad charging dock flex, Replace it with a 100% OG pulled from an iCloud locked phone. Should fix the issue. Cheers!
このアンサーは役に立ちましたか?
Looks power switch flex faulty remove and check. If the problem was the same then try with another middle frame.
このアンサーは役に立ちましたか?
Which part of the log says that?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 11
今までの合計 318
