メインコンテンツにスキップ
2018年9月21日に発売されました。モデル番号A2097, A2098、GSM もしくはCDMA / eSIM もしくはナノSIM / 64, 256、512 GB / シルバー、ゴールド、スペースグレイ。(正しい発音は"iPhone 10 S.")
398回答 すべてを表示
Why won't my iPhone turn on or recognise charging?
My iPhone XS that was previously working just fine one day turned off and now does not turn back on. I’ve cleaned out the charging port, however it doesn’t show the charging / low battery symbol when on charge. I have a USB voltage / current reader that monitors the current draw etc. I’m not sure if this is normal but it is being given around 5v but no current draw. If I try to power on the phone with the buttons, I get a momentary 0.3a current draw for about a second, then back to 0. I have ideas it maybe a battery issue that could be the culprit but the battery health has been pretty good. There’s no water damage and as far as I know it hasn’t even been opened. Any ideas would be helpful, cheers.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
This might be hardware issues I saw many iPhone x/xs/xs max automatically shut down and while repair found shorting. There might be some shorting might be. I think that is the fault related to hardware that can`t be solved from the outer side like charging etc.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brandon Frost さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 59
