Where can I find an extra Tray/Sled?
I have an old (1.1) Mac Pro and I'm missing one of the sleds/trays. I can only find ones that will cost me 40 dollars. Can't find any on ebay either. Where can I buy one for the right price?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
That's the Hard Drive Carrier Apple part number 922-7728. Here's seven available for $19 each: update 3/2013 new link: http://www.amazon.com/Mac-Hard-Drive-Car...
このアンサーは役に立ちましたか?
please note the g5 trays are shorter than the mac pro sleds.
With older equipment you should join LEM swap. This is a google group for older Macs and you can buy or sell parts there. Good luck on your search.
LEM stands for Low End Mac.
このアンサーは役に立ちましたか?
I have just purchased 4 of these from Apple4less.com. based in Ireland. But you need to purchase the screws separately!!
Apple Part No. for the tray/sledge/caddy/bracket/carrier is: 922-7728.
Apple4less part code for the screws is: HDD-SCR-MP-2
I paid just over €14 for each tray, and an extra €7.50 for each set of 4 screws.
Note that earlier versions of MacPro (series 1-4) require a different, shorter tray than later versions. The quoted part number is for the shorter version. My MacPro is a 3.1
Good Luck!
このアンサーは役に立ちましたか?
8TB drives use a new screw pattern, and nobody sells the old 1,1 trays with the new screw pattern. Looks like we're being forced to get the new trays, and dust off the Dremel.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 3,596
