メインコンテンツにスキップ
モデル番号はA1238/80、120、160GBハードドライブ/ブラックもしくはシルバーメタルフロント
906回答 すべてを表示
iPod won't turn off
A number of years ago I connected my iPod classic 80gb to a docking speaker and upon doing so it made a popping noise like static almost. Ever since then the iPod won’t turn off, I think its a problem with the connector inside the iPod, like the connectionists bent or something. The device charges and works fine as long as I have the battery charged, it also maintains a charge, but again it is like its always on. I can restart the device with no problem. nothing wrong with the screen but it runs the battery dead because it won’t turn off. Currently I have it in my vehicle on a USB port that only works with the car is on so everyday it has to charge again before I can use. Any help would be appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Does the iPod turn off if you press & hold the play/pause button for a few seconds?
You can also go to Settings > Main Menu and select Sleep. This will add a sleep button to the main menu.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Stout Germ さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 14
今までの合計 284
