メインコンテンツにスキップ
The Ram line was redesigned for the 1994 model year. Development on a second generation began in 1986, ending in late 1992.
33回答 すべてを表示
My horn is coming on by itself
1999, dodge ram 2500 horn started blowing while sitting in my driveway. Starting the truck and hitting the horn switch on the steering wheel had no effect. Horn finally went off by itself. I was unable to make a positive ID on the horn location, but I think it is located, facing the truck, on the left side under the Battery. Is that the correct location? Ideas on what the problem might be?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @gman1517 ,
Here’s the 1998 Ram Truck 1500 – Horn Systems section of the 1998 Ram Truck 1500/2500/3500 Service Manual + Wiring Diagrams that may help.
It details how to test the horn and also shows its location etc.
Hopefully this will help you to find the problem.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Glenn Geise さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 508
