メインコンテンツにスキップ
Support and repair information for Beats Solo3 headphones.
63回答 すべてを表示
Doesn't turn on but flashes when charging
Hi there, I've had my beats for around 2 years now, yesterday at 7pm I was using them perfectly fine with no problems at all, and then when it came around 11pm it turned on but then shut down after a few seconds, when I put it in charge it shows 3 bars and one flashing so it's definitely not dead, and occasionally it will turn on but turn off instantly, I have tried the factory reset thing so if anyone is having the same problem or has any solutions please reply
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
RayyanS04  the symptoms you describe are pretty consistent with a bad battery. Remember that even a bad battery will tell you it is charging but will not hold a charge. Replace the battery and re-evaluate.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
hi0bui9bvivbibuboihiohi097awrestdyfugihj
IDK why I’m on this site:::::::: This site helps with nothing better just to go get it fixed than waste your time on this site.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
RayyanS04 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 6
今までの合計 206
