Maytag Bravos XL (MVWB835DW2) No water, goes between sense & wash
I was having issues with no water so I replaced the water filters on the valve where the water enters the machine as there was some sediment in one of them. No change so I replaced the entire valve setup (Part # W10758828 - OEM same part # that was in there). I also took the time to clean out the plastic dispenser system all the way to where the soap dispensing takes place to be sure everything was cleaned out well. Still no water. There does not appear to be any blockages with the outing water and it is all in spec with Maytag instructions. When I start the cycle the sensing light comes on then shortly after that the door locks then it senses (drum spins) and it then goes to wash (nothing happens), it does that for a little while then it says wash complete within around 5 minutes. Not getting any errors on the display. Any help would be appreciated. Thank you
