メインコンテンツにスキップ
The ASUS ROG G751JL-BSI7T28 is a high-performance/gaming laptop, released on October 15th, 2015.
1回答 すべてを表示
8gb vs 32gb for Asus Vivobook M712D
Hi, am sorry to pick up the wrong model but I currently have a Asus Vivobook 17 M712D, It has 8GB ram and am planning to upgrade to 32GB of ram. What are the advantages to upgrading ram on this types of laptops? Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @charlyboy ,
Why do you need so much ram?
In the end performance is limited by the CPU type and motherboard i.e. chipset as this is where the bottlenecks usually occur.
Depending on the actual specifications of your model, e.g. installed CPU, GPU etc, according to this review "the notebook is suited for various office applications and can also run simple or older games on low settings”.
このアンサーは役に立ちましたか?
スコア 1
10 件のコメント:
I feel that having 8GB installed isn't enough for multitasking, YouTube videos, and feels a bit snaggy. I though upgrading to a 32GB ram will increase the performance of this machine.
さんによる
@charlyboy
Not sure that your model even takes 32GB.
According to this link (admittedly not for a M712D model which I can't find in Asus website only specs for M712 models showing different cpu, gpu hdd or/ssd etc) it only supports 16GB
Is there an SSD in your model?
さんによる
Yes, it currently has the western blue 256GB SN550.
さんによる
I was wrong, it has an HDD hard drive as its a western blue hard drive.
さんによる
@charlyboy
You will see better overall performance with a SSD installed as well as a ram upgrade, but 16GB should be enough (and maybe all that can be installed anyway)
さんによる
5件以上のコメントを表示
コメントを追加
回答を追加する
Carlos さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 674
