メインコンテンツにスキップ
The Samsung Galaxy A40 was released in April 2019.
28回答 すべてを表示
Black Blobs Appearing on Phone Screen, Can't Access Anything
Hi there, I’m kinda pulling my hair out trying to figure out this mess I’ve gotten myself into with my Samsung A40. My phone hit the ground hard by accident and despite no visible cracks, black/purple blobs have started spreading throughout the screen. Worst of all, touch screen functionality has ceased and I’m stuck in the Lock Screen. Rebooting it doesn’t work, which isn’t aided by the fact that the volume buttons don’t work to reboot it in the first place, so I had to run it out of charge to restart it. Alas, the touch screen still won’t function and the blobs are spreading.
I understand there may be damage to the AMOLED display, but I’m no expert on this. I have a lot of files stored internally that I never got around to backing up elsewhere and I’m very scared of losing them. Is there anything I can do to get into the phone and grab my stuff before the whole screen becomes unusable? Should I turn it off until I know what I’m doing? Is there any course of action I should take to help mitigate this problem? Thank you so much for your time.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
chances are that the battery is damaged and has expanded, causing it to push against the underside of the screen. perhaps replacing it will fix it, but you will likely have to replace the screen as well, however those are relatively easy fixes
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I understand, I'm glad to hear it's hopefully not as unsalvageable as I worried it might be. I'll keep trying to identify the exact issue and if I can't sort out those fixes myself, I'll seek out a repair shop in town that can replace what's broken. Thank you!
さんによる
コメントを追加
回答を追加する
biological frog girl さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 143
