メインコンテンツにスキップ
The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
77回答 すべてを表示
Why did I lose all power and motor starts smoking and oil everywhere
Driving on freeway lose all power truck started smoking turn off I won't turn back on
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@gordoloc we really do not have enough information to even come close to a definite answer. From the little info you are giving us it sounds like you have had a catastrophic failure with your engine. It appears it may have thrown a road or a piston. At this point you will have to start cleaning the oil slick off your engine and remove the shrouds etc. that cover the block. Take a look and see if there is damage to the black. Sometimes a rod can actually come out of the side of the block etc. Next remove the spark plugs and see if you can turn the engine. Use a socket wrench on your crankshaft pulley and see if you can turn the engine. Let us know exact year, model and engine size of your Ram
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Anthony さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 19
