メインコンテンツにスキップ
The Kenmore Elite HE3 is a washing machine by Kenmore.
668回答 すべてを表示
Kenmore elite top load washer uneven
I have a kenmore elite top load washer that frequently gives me the uE or UE code. Normally, I can rearrange the clothes and finish the cycle. We used the sanitize setting with NO CLOTHES to clean the washer and continually got the UE code so that we could not even finish the cycle! Please help! Thank you!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Hi @ttap14,
What is the model number of the washer?
さんによる
The model number is 796.3152
さんによる
@ttap14
Does the washer move or the tub "bang" during the spin cycle at all?
さんによる
コメントを追加
2件の回答
最も参考になった回答
@ttap14 @jayeff it could be the stator that causes this. I had to replace the complete stator in my Kenmore HE3 due to a wore out hub. It would trigger the UE code first only sometimes and then just much more often until it finally would not work at all. I suggest you go ahead and check it out. Post some good images of what you find on the hub and spline. iFixitでの質問に画像を追加する方法 See if it is wore out as well. It is not a terribly complicated job but definitely works better if you can lay your washer on its back etc. Use this Elite HE3 Service Manual to work on your washer. Page 53 part number K201 is what I had to replace. Wasn’t easy to find for my model and you definitely need a big wrench and a big hammer :-)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
there are a lot of answers available if you google Kenmore Elite HE3 UE code.
try that first.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Trapper さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 18
今までの合計 713
