ASUS TUF back panel not coming off.
My ASUS TUF FX505DT back panel is not coming off…i did unscrewed all the screws, but the back side(near the radiator) is seems to be stuck..i tried every ways…pls help…i just want to clear my laptop.
Hey Sleepy,
Do you have a spudger or old creditcard/giftcard? You can use those to wedge between the plastic. Just make sure not to use anything metal, like a screwdriver, because that will jack up the plastic.
Hope this helps.
このアンサーは役に立ちましたか?
ok thx i will try..
here is a screen placement video on YT i found, good luck!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 182
