メインコンテンツにスキップ
モデル番号A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5もしくは 3.4 GHz Core i7 Processor, ID iMac12,2
708回答 すべてを表示
amd 5770 vga card died, need compatible replacement (2011 27" EMC)
What other vga card will fit the iMac mounting board and the heat sink?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
Technically its not a VGA card, its a Mobile PCI Express Module (MXM board)
さんによる
Thanks, I always wondered what MXM meant
さんによる
コメントを追加
1 件の回答
Apple offered three AMD boards for this series:
  • 661-5967 - Radeon HD 6770 (512MB)
  • 661-5968 - Radeon HD 6970 (1GB)
  • 661-5968 - Radeon HD 6970 (2GB)
Be aware these boards have custom firmware so unless you have the tools to reburn the EEROM you need to stick with the Apple boards.
Apple also changed things with newer macOS releases so unless they support Metal services you can’t run these older GPU’s. Some people have used NVIDEA boards which offer Metal services, but they often need EEROM programing and the NVIDEA driver is running in compatibility mode so many hardware improvements NVIDEA added are not supported. Apple never gave NVIDEA the needed info to update the OS drivers.
It’s also likely macOS will be dropping Intel support soon, if not more limited given the new features won’t be made available on Intel systems.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
macisgr8 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 20
