メインコンテンツにスキップ
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459回答 すべてを表示
Won't Charge Or Displays Caution Sign During Power On Attempt
I know this is a pretty dated piece of tech, but I have pictures and contacts in the device that I need. I’ve tried different chargers and different plugs, but the result is the same. Changing batteries have given me the results of a black screen or a caution sign inside the “charging battery” animation upon start up. I’m just looking for some help so I can get what I need off of there. If anyone has any ideas I’m open to any and all of them. Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I repaired alot of these devices back in the day and the fault you are describing is almost always the Charging Port Flex Cable.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
What exactly do I have to do to the flex cable? Is it loose or do I need to replace it? And where is it located?
さんによる
@jjmarcus143 Sorry, I thought it was a Galaxy S4 for some reason. Galaxy S3 is just a port, not a flex cable. But unfortunately, I'm not sure what could cause this on this model.
さんによる
Dang. Alright I appreciate the response.
さんによる
コメントを追加
回答を追加する
Jamarcus さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 28
