メインコンテンツにスキップ
2020年にAppleより発売されたトップラインのスマートフォンです。iPhone 12 Pro Maxは11月13日に発売されました。6.7インチ OLEDディスプレイとLiDARを搭載したトリプルリアカメラシステム、5Gネットワーク接続が可能です。iPhone 11 Pro Maxの継続モデルです。
77回答 すべてを表示
Drawing ~.38A and no signs of life
Hi there, I recently purchased a 12 pro max off ebay. Listing stated it had been dropped (two of three of the lenses were broken) and was working, they turned it off and then it wouldn’t turn back on again. Said the screen was working fine. I’ve tried recovery mode, buttons, nothing comes up in itunes, although when hooked up to my usb tester it shows .38A draw (not the most exact on low drawing items but definitely shows it’s drawing power). What could be the cause and remedy. Is there a way to test the battery itself for voltage? TIA
UPDATE Placed it on a wireless charger. Drawing ~.9A and when I try to put it into recovery mode it cuts all power and resets the wireless charger before beginning to charge again.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
If you brought a non-working phone from eBay you will have to assume it will not be an easy repair as the seller probably has had some one already look at it and since it is a new model makes it even harder. I would at least try another battery but I don’t think that will be the problem as your amp reading would point me to a short on the logic board or part connected to the board.
You could start by disconnecting all the flex cables except for the battery, charge port and see if your PC will recognise it. You will probably need to put it in recovery or DFU mode for it to be recognised. If that doesn’t work.
·         You will need to completely rule out parts by installing the logic board into a known good housing with a charged battery.
·         If it still will not boot you will need to start checking power rails.
The first line to check would be VDD_MAIN followed by the NAND power rails, this will be tricky if you are not an experienced repairer as there are no schematics for the 12 Max pro yet.
You will at least need the following equipment.
·         Multimeter with needle probes.
·         DCPS with squid leads.
·         Microscope.
·         Hot air station
·         Soldering station.
·         Heating and re-balling fixture as this board is soldered together in two halves and will most likely have to be separated and re-balled.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
micahzuglian0 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 97
