メインコンテンツにスキップ
これらの交換部品ガイドを使って、Samsung Galaxy Watch Active2を修理しましょう。
45回答 すべてを表示
My touch screen doesn't seem to be working on my Samsung Active2 watch
The screen on my watch doesn’t seem to be working. I can’t get into any of the widgets. It doesn’t seem to be “feeling” my taps. Is this repairable?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 9
コメントを追加
4件の回答
最も参考になった回答
Along with this issue a few users are facing issue with their watch that it keeps responding without any touch. So, here are a few methods to fix the watch facing Ghost Touch issue.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Actually from the searching around I did. I found out that repeated sloppy water exposure were the common tigger for ghost touch. The glue on the active 2 isn’t the best, some watch even open by themselves because of heat and normal use. Soppy water seems to more easy get to and damage the screen digitizer. If you wear a case over the watch it kill it faster because the humidity is getting trap and end up going insides the watch.
さんによる
Can this be fixed? I noticed it started after high humidity and having a screen protector over it
さんによる
コメントを追加
Hi gary & chris,
you might want to check if the display connector sits properly on the motherboard or see if there is any dirt or remnants of water inside the watch which may affect the touch function of the display.
See this back cover guide to get inside. The top connector in the last image is the display.
Also you can read this thread (Samsung forum) on water damage on Galaxy watches for more background information.
If still under warranty from Samsung you may be eligible for a replacement or repair.
Samsung Galaxy Watch Active2 Back Cover Replacement
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Bought a decent Y00 as didnt have one, but %#*@ screws were in so tight i ended stripping the heads trying to get them out.
さんによる
コメントを追加
Software update...us
But not working my whatch
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
From the « research » I did (basically I read through a lot of other people that the issue wasn’t fixable by software). I found out that repeated sloppy water exposure were the common tigger for ghost touch. The glue on the active 2 isn’t the best, some watch even open by themselves because of heat and normal use. Soppy water seems to more easy get to and damage the screen digitizer. If you wear a case over the watch it kill it faster because the humidity is getting trap and end up going insides the watch
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I think you are also right men
さんによる
コメントを追加
回答を追加する
gary & chris vance さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 66
過去 30 日: 313
今までの合計 16,914
