car idles high then drops and does it again
92 civic idles high and drops then does it again between 1000 and 2000 rpm
この質問は役に立ちましたか?
この質問は役に立ちましたか?
This is a very common thing with honda's. What it usually means is that your low on coolant so first thing to check is your coolant level and if that is fine i would check your coolant sensor that gives the signal to your ecu and make sure the resistance is within specs. That is the most common issue and fixes for that issue, if problem continues check the resistance from your tps and map sensor.
このアンサーは役に立ちましたか?
+ that is great to know. Thanks.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,595
