メインコンテンツにスキップ
The US version of the sixth generation Sonata was unveiled at the 2009 Los Angeles Auto Show, with sales beginning in 2010 for model year 2011. For the US market, the sixth generation Sonata boasted a direct-injection 2.4-liter four-cylinder engine.
21回答 すべてを表示
Visor will not stay in the folded upright position
We purchased another from a parts/junk yard place. Same thing. Passenger side.
ALSO, the door handle Driver side rear pulls out and no longer working.
Is the Hyundai Sonata poorly created esthetically?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
Don’t know about the visor but here’s the Sonata YF/i45 2010-14 – Body (Interior and Exterior) section from the service repair manual that may help with the door handle problem.
When the document opens click on the magnifying glass icon on the top left of the document header bar and type door trim replacement in the search box and then click the arrow to select 2 of 2 matches. There is no page numbering in the document so this is the easiest way for you to find the correct section without having to scroll through the whole document.
This will take you to the start of the section that shows how to access the rear door inner and outer door handles to check whether the connecting rods are securely attached etc. (you don’t state whether it is the inside or the outside door handle that is the problem).
Hopefully this is of some help.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
bdszabo2 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 94
