メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
431の回答 すべてを表示
Installed RRoD repair kit, now I have video problems with HD component
I installed RRoD kit, reflowed motherboard and repair seems to have worked but....when I hooked the Xbox up with component cables there is a vertical line down center of screen with a double display. Unit works with Standard definition cables and also with PC cable. Is this a problem with the cables or did I damage the graphics card?
Dave
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
What exactly do you mean by double display?
さんによる
コメントを追加
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 件の回答
最も参考になった回答
It sounds to me like that would be a case of bad cables. Do you have a friend that has the hd cables? If you do and you know they work on his console this would be a good way to test for the real problem.
Hope this helped,
Cody
この回答は役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
daveboulanger さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 594
