メインコンテンツにスキップ
Microsoft Corporationが設計したXbox One Sは、2016年8月に発売されました。Xbox One Sは、Xbox Oneを再設計した製品です。
428回答 すべてを表示
One S no image, doesn't shut down, can't reset video settings
Hi,
I have an Xbox One S which doesn't output any video signal, even though it turns on.
When I press the power button while it's on, I do get the “shutdown” chime, but it doesn't turn off (light stays on, fan keeps spinning).
And when I hold Eject and Power to reset video settings before turning on, the light comes on after ~3sec but I dont hear any chime, and the console goes into the state I described before.
I've replaced the HDMI controller (75DP159) but it didn't change anything. And I know that the original one was perfectly functional.
In short, I'm stuck here.
Thanks for the help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
gonna ask it cuz you didnt mention it.
did you make sure none of the pins on the HDMI are bent or messed up?
check the pins on the back of the connector also.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Okay, problem solved.
Apparently the One S can sometimes do that when the hard drive is failing.
Which is the case for me, I just needed to change the HDD.
You can also test for this issue by plugging in a USB stick that has an LED.
If the LED doesn't light up, it seems to indicate that the console is trying to boot from the HDD but can't and gets stuck in this state. So it doesn’t even load the USB stick.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
rzkruspe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 33
