I moved the refrigerator on its side, now it blows only warm air
I moved a refrigerator layin it on its side. I set it up, waited 4 days, plugged it in and it only blows warm air. Is there anything I can do to fix it?
Check to see if the compressor is running. If not, you'll need a meter to see why. Incoming power to compressor? Start cap good? If the compressor is running, is it really hot? Is the hot gas line hot? Line from compressor warm? Suction line cool? Condenser fan (if it has one) running? Is the evap fan inside the freezer running? Check it out and see what isn't running.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 30
