Battery not registering after installing new ifixit battery
I installed a new battery using the ifixit kit and followed the guide but now my mac power on without the use of the power cabel
Hey Ravi,
Pull the power and any other cable. Take the battery out and hold the power button for at least 15 seconds.
Put the battery back in then plug the charging cable back in. Try restarting the laptop like normal.
Hope this helps.
このアンサーは役に立ちましたか?
Thank you for the advice, unfortunately, this did not work, someone who had a similar problem said it was because the battery they used had old firmware so need to a new version which might the case for me as well.
Try the original battery? you might have broken the board while unplugging it?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 38
