Inner tub won't fill with water
I have the Kenmore Elite 700 top load washer. We moved it 25 feet and reconnected it and now it will not fill the inner tub with water. All hoses have water flow and screens in water intake valve have been cleaned. Any suggestions please? It will even begin wash cycle with no water in it.
5 件のコメント
Hi,
What is the model number of the washer?
Does it do this when either water temperature is selected i.e. hot or cold or only when using the one setting?
it may be a problem with the water inlet solenoid or the water level pressure switch telling the control board that there is already enough water in there when obviously there isn't
jayeff さんによる
Hi there, thanks for the input. The model # is
11031633611.
I am seeing if my husband can bring home the thing that can check the water input valve solenoids.
It does this no matter what water temp its set on
ashley smith さんによる
Also wanted to add that I can hear it letting water into the unit, but not getting into the tub. And when I power it off, it automatically drains, and water is coming out if the drain hose.
ashley smith さんによる
@ ashley smith
The model number would really help.
If parts are required then at least you know that you're getting the correct ones for your exact model
jayeff さんによる
@jayeff I posted it and the robot kicked it out as spam, but I contacted them and had it reposted. Its in my comments above. Hope this helps
ashley smith さんによる
