メインコンテンツにスキップ
Repair guides and support for coffee makers by Keurig including the K-Cup systems.
497回答 すべてを表示
Keurig K-Mini powers on but doesn't brew (brew mode won't activate)
Got a brand new Keurig K-Mini as a gift. After filling the reservoir with water and pressing the power button (which lights up) and after lifting and lowering the handle to activate brew mode, the brew indicator light doesn't flash and nothing happens when I press the big K button. What happened? What should I do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I had this problem too. I think the switch that activates when the handle is closed wasn’t working properly. I was able to hold the handle slightly open and press the big K brew button. I had to alter the angle of the handle until it worked. Once it started, I simply closed the handle all the way. It doesn’t fix the machine, but it’s a hack that lets me make coffee.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you, a little twist of the handle and it worked like a charm. I had cleaned and reset it a few times.
さんによる
コメントを追加
回答を追加する
Alexa Marie Paden さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 34
過去 30 日: 131
今までの合計 3,689
