メインコンテンツにスキップ
The Sony SRS-XB22 is a Bluetooth speaker released on 25th March 2019 and has since been superseded by the SRS-XB32.
1回答 すべてを表示
No sound from Sony SRS-XB22
Suddenly no sound, voice prompts, or music. Fully charged, reset and factory reset. Only used 5 or 6 times. Tried connecting to several devices that had worked, iPad, iPhone,iMac and Toshiba tv. All had worked in the past with this speaker.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Hi @rick11 ,
Do you get sound when connecting audio via a stereo audio cable to the speaker's Audio In socket?
さんによる
I tried that with no luck@jayeff
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi @rick11 ,
You said that it has only been used 5 or 6 times. How old it the unit and have you had it since new?
Depending on where you bought it etc there is usually a 1 year (12 month) manufacturer's warranty on the speaker (unfortunately only 90 days in the USA).
Check the user manual or online, for the warranty details pertaining to your location.
If the warranty period is still valid, I suggest going the warranty route first to get it fixed, replaced etc, before opening the speaker to check what may be wrong. Opening the speaker will void the warranty.
If the warranty period is over then you may have to open the speaker to check for any obvious problems e.g. burnt out components or loose connections etc.
Here’s the Ifixit SRS-XB22 Battery Replacement guide. It is useful as it shows how to open the speaker.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for your reply. I bought this speaker privately some time ago. It was new but had no warranty. I’ve already opened it up and disconnected the battery for a half hour just in case something weird got saved. Sony support said it sounds like something is wrong internally and I should go to an authorized service center and have it repaired. I’m thinking that I just learned an expensive lesson.
さんによる
コメントを追加
回答を追加する
Rick Hunt さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 11
今までの合計 388
