There is sound and picture. However, the screen like solid white background made the picture faded.
The issue actually started with flickering at start up and the picture normalizes after viewing for like a minute or 2. The issue became progressive until it started displaying the faded picture with white background. Please see images attached
Note: it is the white background that made the picture faded. And it also exists on all input/no input even when u are in the secret menu, u will still see the white background.
Hi @waterkunle ,
Is there sound on the TV when there is no picture?
Have you tried a different signal source e.g. a dvd player and see if the TV worked OK when using it as the signal source?
Can you view the TV menu screens OK?
jayeff さんによる
Thanks for your time
Mutiu Omobolaji さんによる
@waterkunle
Have you tried adjusting the contrast setting?
jayeff さんによる
I have tried all in-system/picture adjustments. No headway
All was well until the flickering started which eventually ended in that solid white background
Could you please give us the full model number? For example: Samsung UE43TU7100.
TechWizard さんによる
6件以上のコメントを表示
