メインコンテンツにスキップ
2.0GHz, 2.3GHzもしくは2.6GHzクアッドコアIntel Core i7プロセッサ (Turbo Boost 最大3.8GHz) 6MB共有L3 キャッシュ付き。
580回答 すべてを表示
Can I use the screen assembly from a late 2013 MBP on a 2017 (15")?
My son spilled a water on my late 2013 MBP, and after a logic board cleaning and replacing the dc power adapter, I still get nothing when I plug it in.
I found a cheap 2017 15” with a broken screen, and wondered if I can swap out the display from my old one on to it. The compatibility lists I have been finding don’t really give me a solid answer.
Thanks in advance.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
It’s a physically larger screen so I would imagine it wouldn’t work. Have you tried connecting the liquid damaged machine to an external monitor? I have the same one myself and I know they have an HDMI port.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Okay, that’s what I needed to know. As far as I could tell the late 2013 screen is only compatible up to mid 2014.
It has no power, so nothing from the HDMI cable. The MagSafe doesn’t light up when plugged in. I replaced the DC adapter to no avail.
just now by dave
さんによる
@daveybuoy then you might want to send it to Rossmann Repair. The owner Louis is a MacBook board repair specialist in NYC and he's got a youtube channel you can check out
さんによる
コメントを追加
回答を追加する
dave さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 21
