メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年秋に発売されたLGの大型スマートフォン。LG G3(D855)はQuad HD IPSディスプレイと1300万画素カメラを誇る。
Won't power on not recognized by pc
I have an LG g3 I had someone bring me to try to pull data off of. Normally I'd just say it's dead and you're sol. I tried booting with battery in, and plugged into wall power, no go. No charger light shows, plugged into pc and it's not recognized. I haven't tried a new battery yet but I did try booting without battery and no go. I seems YouTube video that said it's the power button and common on these g3 and G4 I had a G4 myself personally this same thing happened to. I would not mess with it at all but the data is of a girl that was 7 that died. I'm trying to pull the data with my heart going out to the owner that this is where a lot of pictures of her are from before she passed away. I wanted to at least try everything in my power to get the data recovered. I seen a YouTube video but the dudes head is in the way of how he pressed the connectors on the Mobo to get it to boot. I also seen someone say something about putting it in the freezer to get it to boot. Haven't tried that yet. Has anyone run into this and is it usually the battery, power button, or what is common to try to see if I can at least get it to boot once to get the data. I assume there's no other way to pull data off of it if it isn't recognized via USB. I have plenty of forensic investigator tools but if I can't get it to power up or be recognized via USB I figure their a crap shoot. Could it be the usb port went bad? Looking for suggestions and recommendations to try to help this lady out. I planned to charge for the recovery if I fixed it or got them but hearing this story I don't have the heart to do that.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
I'll give replacing the battery a shot. I tried the removal already no dice. I tried putting it in the freezer lol. I seen a video of someone doing something with a heat gun but I can't make out what he's doing because it's on YouTube and in a different language. But I'll see if that helps replacing the battery and report back.
さんによる
Ordered a new battery got it to boot once and was able to recover pictures from it. Which was my goal it was for a lady who's seven year old died.. after recovering them it shut off and now has blue screen of death when booting up lol. But I'm not messing with it because she's not worried about fixing it since she got all the pictures!
さんによる
コメントを追加
1 件の回答
ベストアンサー
If the phone won't boot at all, the issue may be the power-related. Try removing the battery for 10 minutes, and then put it back in. Then try turning it on again.
If that doesn't work, try replacing the battery.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I'll give that a try. Removal didn't work. I will report back. I seen a dude with a heat gun on YouTube to something but I couldn't make out what he was doing as it's in a different language
さんによる
コメントを追加
回答を追加する
William Scott さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 14
今までの合計 562
