メインコンテンツにスキップ
Googleの第3世代Pixelスマートフォンで、Googleの最先端カメラを搭載しながら低価格設定のモデルです。カラーバリエーションは、ジャストブラック、クリアリーホワイト、パープリッシュから選べます。2019年5月発売。
69回答 すべてを表示
Replacement screen not working properly for dimming below 30%
I finally installed my replacement screen from ifixit yesterday, double checked it worked by turning on the device, before I glued it in place. Unfortunately I did not check the screen functions more thoroughly. When the screen brightness dips below 30% the backlight doesn’t continue it's gradual dimming, but shifts to a dark reddish hue making the screen unreadable at low brightness. Is this a known issue or easy to fix? May it be because of a faulty connection between the screen and the phone or is it a defective screen?
Thank you in advance for any assistance on resolving the issue.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Sounds like it could be one of the following:
Bad connection - Reseat LCD ribbon cable
Backlight circuit damage - Caused during the repair would need to be tested with the multimeter
Or and god forbid it, but maybe the screens a dud. 1 in every 10 screens we buy-in for our customers seem to have a slight defect or just dead on arrival from the suppliers.
I would try reconnecting the LCD first, give the phone a force restart, this can help. Then put a support request in with iFixIt, while you wait, see if you can find a bad backlight circuit on the board, if there is one.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Martin Fischer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 158
