メインコンテンツにスキップ
2.5GHzデュアルコアIntel Core i5プロセッサ(Turbo Boost使用時最大3.1GHz)、3MB共有三次キャッシュ
277回答 すべてを表示
MBP Not Detecting Battery
After replacing the faulty speakers of my MBP in-line with the iFixit guide, the device stopped detecting the battery. At login, the battery icon shows 0% for a couple of seconds, then shows an “X” icon. Also, System Report does not identify the battery.
I have tried removing and re-connecting the battery, and both SMC and NVRAM.PRAM were reset, but to no avail. The laptop works fine with the power cord, sometimes slightly laggy.
All was working fine prior to the speakers replacement.
Any help would be greatly appreciated. Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Given the age of your system I think it just was its time.
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see iFixitでの質問に画像を追加する方法
That should nail things down.
さんによる
After answering about what @danj is asking bout - Did you happen to use a plastic tool to lift up on the battery or something metal? I ask because we see this happen quite often if a few of the battery pins are shorted out.
さんによる
@danj For some odd reason, CoconutBattery quits unexpectedly.
さんによる
@joesipaq I did use an iFixit plastic tool to lift all connections during the whole process.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
I fear the battery cable got damaged during your repair as CoconutBattery will react this way when it polls SMC and can’t get any data. Remember your SMC data was lost when you disconnected the battery for a length of time.
Time for a fresh battery MacBook Pro 13" Retina (Late 2012-Early 2013) Battery and here’s the guide MacBook Pro 13インチ Retina Display Late 2012 バッテリーの交換
MacBook Pro 13" Retina (Late 2012-Early 2013) Batteryの画像
製品
$99.99
このアンサーは役に立ちましたか?
スコア 1
コメント:
After looking at other threads with similar problems, I tried pulling out the power cord when powering on the device, once hearing the boot up chime and the MBP remained ON until I entered the passcode.
Could this mean that something else is faulty other than the battery connector?
さんによる
@bugie - Is CoconutBattery now working? If not it doesn't change then its still the battery.
さんによる
Unfortunately, CoconutBattery is not working, even after a fresh OS install. Will consider replacing the battery than. Thanks a million!
さんによる
コメントを追加
回答を追加する
julianbugejacoster さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 35
