adds rinse H2O, agitates, drains fast, pump keeps running dry, no spin
Removed wet clothes, drain with drain tube, and check filter. Filter is clear. Hose from water level switch to drum is clear (blew air through it).
Run rinse and spin cycle - Water enters drum, drum agitates in a regular pattern alternating a few revolutions CW then CCW. This goes on for several minutes. When completed. all the water is pumped out very quickly. So I am pretty sure its not the pump or the hoses. However when all water gone, I can hear the pump continue running (dry) but spin cycle does not start. After several minutes of this, ND code appears. ND=not draining but I know it is drained?? Fill level switch? Door Lock Switch? Ideas?
Update (04/25/2021)
Sorry, forgot to mention model is front loading Kenmore 402-49032011. I did not find this in the list but very simiar to Samsung models I see.
