メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
627回答 すべてを表示
Why won’t my controllers or USB ports work
My wireless controller will not sync with my console with or without USB connection. The synch button on my console doesn’t work either. I purchased a corded controller to see if that would bypass the problem. I have tried all of the troubleshooting problems and have discovered that the USB ports and wireless/wired controller work after a hard shutdown. The problem is the second time I turn on my console it happens all over again. So it seems unless I find a fix I have to hard kill my console every time which you can imagine is annoying given I can’t resume gaming where I left off and the boot time is MUCH longer. I can’t find anything that relates to my problem and the research I have done would make me believe Microsoft doesn’t support this kind of repair.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi David,
So this would be either a motherboard issue OR software issue. As you said that it is working after a hard reset, it do sound like a software issue. Did you tried to reinstall it completely?
このアンサーは役に立ちましたか?
スコア 0
コメント:
I had performed a factory reset that kept my games and apps but that didn’t help
さんによる
Alright. I recommend to do a full restore. So that everything will be removed and that you need to start from scratch (format and install). Perhaps that will resolve it.
さんによる
Full factory reset did not resolve issue. Not sure where to go from here. I’d rather no have to full shutdown every time I want to log in and then wait forever for game to boot because I can’t resume where it left off. Ugh
さんによる
Hmm, weird. Perhaps you need to replace the front panel board. It's related with the sync button.
さんによる
@dan0 that is a great thought. Would the WiFi card have something to do with it as well?
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
David Walker さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 119
