Can’t turn on,
Can’t turn on, when plugged to charge it turn on immediately by self but can’t control, can’t connect . When unplugged it immediately turn off by itself also
Do you know what is issue?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
its in demo mode?, if i remember press and hold the Power button and play button simultaneously until it turns off, then you can turn it on and do a reset by pressing play and volume up button until it turns off, then you're good to go.
このアンサーは役に立ちましたか?
That didn’t work for me now what?
After a few tries, I was able to fix it with this tip! Thank you 👍🏻
このアンサーは役に立ちましたか?
Any progress on that problem? I'm having the same problem now.
過去 24時間: 1
過去 7 日: 5
過去 30 日: 18
今までの合計 2,003
