メインコンテンツにスキップ
2020年にAppleより発売されたトップラインのスマートフォンです。iPhone 12 Pro Maxは11月13日に発売されました。6.7インチ OLEDディスプレイとLiDARを搭載したトリプルリアカメラシステム、5Gネットワーク接続が可能です。iPhone 11 Pro Maxの継続モデルです。
108回答 すべてを表示
Does the camera have anything to do with flash?
My iPhone 12 Pro Max fell from me, and the camera broke and did not work, and the flashlight also does not work, but I do not see any defects in flashlight, and I want to order the camera from outside the country in which I am in. Do I need to order the flashlight also?  Or is it that when the camera is not working, the flash will not work as well?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
The rear camera assembly and flash light are different components. Just be aware that when you change the cameras in the 12 series, it will display a message saying “Apple is unable to verify this is a genuine camera” upon turning the device on, even if you purchased another 12 pro max from an apple store and swapped the parts, it will still display that message. Don’t worry, it will not hinder the performance or usage of the device. It’s basically there to tell you, “hey your device has been opened or repaired.” Don’t let the message scare you. As long as you do the repair right, the camera should work just fine. Similar messages appear whenever you change the screen and the battery as well. Also keep in mind that when you open the device, you will permanently lose liquid resistance. You should replace the seal but even then it’s not quite as good as OEM so make sure you keep it away from liquids as best as you can. Use acetone and some Q-tips to clean the frame so the new seal can adhere better.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If I changed the camera, the flash will work or not?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Flash will work no issues. It isn't dependent on the camera module, Flash and Power button are interconnected so as long as your Power button is working your Flash also should be working fine!
さんによる
コメントを追加
回答を追加する
Abdulmalik さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 400
