Can anyone tell me how to replace board mounted USB3 B socket?
My Fujitsu IX500 scanner was working great, but the USB3 B female socket had broken off leaving 4 bare wires without that center post. I have the logic board removed, and before diving into a soldering job, I am hoping for some tips replacing this 9-pin + 2 post board-mounted port. Since a replacement scanner is $500, I am willing pay a professional to do the repair if advised.
この質問は役に立ちましたか?
2 件のコメント
Charles, I have the same problem - how did you resolve yours ? I am thinking of having a go at replacing it myself.
David Evans さんによる
Can anyone lend the exact part number from digikey.com? I’ve browsed and appears to be a couple potentials listed under USB 3.0 Connectors.
I’ve had my Scansnap for 5 or 6 years and the internal, port prongs got smashed inward because someone plugged the wrong size cable into it. Any assistance with the matter would be appreciated.
What I believe it may be: USB-B (USB TYPE-B) USB 3.2 Gen 1 (USB 3.1 Gen 1, Superspeed (USB 3.0)) Receptacle Connector 9 Position Through Hole, Right Angle
Digi-Key Part Number: 123-A-USB3B-ND
Lead time states 21 weeks - hopefully that’s incorrect.
Paul Atreides さんによる
