メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Can water get trapped under the screen resulting in an odd white stain
I was cleaning my iPhone 5, I used an old toothbrush to get gunk out of the small crevices. I also used electronic wipes near the silent mode switch. I powered the device back on, and when it was booting up I saw a large white stain on the corner of the device. It slowly disappeared after a few days, but it’s still somewhat there. Is this water? Is it permanent? How can I fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
im pretty sure if its caught between the glass in the LCD you might be out of luck. can u take a picture of it?
i would go into this expecting to have to replace the screen but one thing that i would try is trying to get some alcohol in there. use the highest percentage you can find though. 90+% id say 99 if you can get your hands on it. let it soak through and then air it out for a couple of hours ATLEAST and then try to power it up and see how it looks before completely reassemble.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Can I use hydrogen peroxide?
さんによる
i wouldnt. that stuff would probably cause alot of bubbles and what not to be trapped. alcohol is your best bet as itll evaporate on its own.
さんによる
コメントを追加
回答を追加する
Rob さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 60
